Breaklines won't print!
Recently I've found that my break lines no longer print even though they show normally on the screen. I've tried different line fonts and still no printing. I just tried the same thing from another SWX installation and it prints A-OK.
This appears to have started with the installation of SP4 (the neighboring machine is still on SP2). We're running SWX 2004 under Win 2K.
Anybody had similar issues?
RE: Breaklines won't print!
Go to System options, Drawings and check "Print breaklines in broken views"
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
The ironic thing is that I actually recall reading the original thread. That'll teach me to post without doing a search first.
If I hadn't been routed to the VAR voicemail I wouldn't have even posted.
Thanks again.
