14 Gauge steel tolerences
I'm looking for the inherent minimum bend tolerence for 14 G steel.  Is there a good book/soure where this can be found?
Cheers!
Joe
RE: 14 Gauge steel tolerences
Ehhh there is no inherent min bend for 14Gauge.... You'll have to figure out which temper youve got and what quality. Then from teh rockwell B value and a good steel hand book you cna get the minimum bend radi for perpendicular and parallel bends.
nick
The rule of thumb for low carbon steel is 1 x thickness is the minimum bend radius. There are special cases though. Reducing the carbon to .05-.10 improves the bendability and bending across the grain will allow smaller bend radius. These assumptions are for air bending where the die opening width is 8 times the material thickness. If the die opening is greater than 8T than the radius on the part will not match the punch and will not be a smooth radius.
In practice unless you are willing to spend additional money for non-standard bending tooling you will be bending 14ga with a 1/16" radius punch and utilize a 5/8" vee die. You could probably use a 1/32" radius punch however the part will come out with a distorted (non-radius) bend and the punch will have excessive wear.
