Dimensioning part level sketch in assembly level drawing
Wondering if anyone might have run in to this problem in SWX 2004, sp4.0:
-create a 3D sketch in a part
-insert that part in to an assembly
-create a drawing of that assembly
If you're like me, you'll be unable to select that 3D sketch for dimensioning, even though it is displayed on the drawing.
The workaround is to create another 3D sketch at the assembly level in-context of the part level sketch, but then there's another feature to maintain.
Any insight is much appreciated!
RE: Dimensioning part level sketch in assembly level drawing
Bradley
I would try repairing your install of SW. FAQ559-908
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
