fluid speed vs pressure
Please someone tell me the Physics Law that states that The Speed of a liquid in a pipe is slow when the pressure is heigh and the speed is fast where the pressure is low.
Keith
kd@tnni.net
Keith
kd@tnni.net
RE: fluid speed vs pressure
Good luck,
Latexman
Total pressure =static +velocity (or dynamic) pressure
so if SP=10 and VP=10 TP=20
if you speed up the system, (and have no losses) then the VP goes up and the SP goes down but the total is the same
voila
SP=5 VP=15 TP=20
etc
Friar Tuck of Sherwood
The two responses above while correct, are not really on the mark.
In Oil & Gas operations we often talk about velocities being greater at low pressures. What is left out of that statement is "for a constant volume flow rate at STP, actual velocity will be higher at lower pressure".
We're always talking about volume flow rate at STP (and we assume that everyone has the same defination of STP). So when someone says "the critical flow rate in 2-3/8 tubing at 10 psig is 100 MSCF/d and at 500 psig it is 900 MSCF/d", they are probably using a program like Perform or Prosper to calculate a critical flow rate behind the scenes. The terminal velocity at flowing conditions underlying the programs is pretty similar between the two cases, but when you do the conversion to standard conditions the numbers are far different.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The Plural of "anecdote" is not "data"
The flow work when the liquid is displaced through a volumetric space 1/ρ against the restraint of pressure p is p/ρ.
The kinetic energy per unit mass is v2/2.
The potential energy per unit mass with the horizontal reference level 0-0 is zg.
Bernoulli's equation for frictionless flow is:
p1/ρ + V12/2 + z1g = p2/ρ + V22/2 + z2g
Dividing by g all the dimensions in the equation are in units of length, e.g., m.
Multiplying by ρ all the dimensions are in units of force per unit area, or pressure, e.g., N/m2.
Thanks! How do you get your replies to be in various fonts/styles?
Good luck,
Latexman
Good luck,
Latexman
As a former Naval Instructor, I had to find a way to relate pressure and velocity, besides stating Bernoulli's Theory.
Here is a simple example I used and that all the sailors I taught thoroughly understood;
(1) You and your buddies are sitting in a crowded bar.
(2) A fire breaks out.
(3) There is only one door.
(4) Everyone rushes to the door.
How long does it take to get to the door is your speed. How many people standing, pushing, and shoving to get through the door can actually be measured if you had a scale on your back and everyone behind you is pushing on it. That is pressure or force. Or in simpler terms count the number of people within a 10' x 10' square near the door. That gives you the bodies per square foot. It will be alot.
Now hear is the ringer? How many people can go through the door at one time is determined by pressure or how many people are pushing on those at the door. Keep in mind that as you ran from the bar stool to the door, your speed dramatically decreased. Actually came to a screaching halt.
As you finally exit the door with your shirt almost on fire, what do you do? You run because there are very few people around you. Thus, as you exit the door your speed will increase but "bodily" pressure decreases.
Todd
www.oxilume.com
That is one of the best explanations I've heard in all my life. The fact that it is so simple that any everyday person can understand it underlies its genius and therefor the depth of your understanding of the subject.
Well done!
remove.marius@mailbox.co.za
We deliver steam as if your life depends on it.
A pressure gauge on a liquid line shows the pressure drop occuring after the point where it was installed. Suppose, I have two horizontal pipelines(different sizes) kept side by side and with the ends open to the atmosphere. Let us also assume the pipes are full and velocity in the bigger pipe is lower than that of the smaller pipe(let us further assume flow is constant in both the pipes).
Neglecting any other losses except friction,
Hf = flv2/2gd, increased d and reduced [/b]v[/b] should reduce Hf
PS: I a speaking about constant cross section pipelines here.
This is not as complicated as it seems. In my example I totally disregarded any difference in friction drop, by locating both gages at a short distance one from the other. That's also the reason I said: "chances are...".
If, on the other hand, the gages were located far apart, the friction drop may have "eaten up" the corresponding pressure "gain" due to velocity "reductions" and the downstream readings would probably become lower than those upstream.
I initially misunderstood your post by considering two different size pipes placed side by side. I overlooked the word segment.
I'm new to the field and I have a pretty simple question I think...How do you calculate operating pressure in your system. I have a Chilled water closed loop...40 ton chiller to cased chilled water coils. ewt=45 lwt=55. Is it as simple as converting my head on my pump to psi?
Regarding Bernoulli's equation. Will a flow with high static pressure, low velocity have the same impact on a blockage in path as a flow with low static pressure and high velocity.
Thank you
A short answer would be: no.
The force of impact of a fluid stream on a perpendicular stationary plate is estimated from the law of conservation of momentum as:
Bernoulli's equation is used, for example, to estimate the velocity of a fluid using Pitot tubes by measuring the stagnation pressure from the kinetic energy component converted into head, corrected by a factor that depends on the geometry of the Pitot tube.
When a liquid of density ρ, moving at a speed V in a rigid pipe, is suddenly stopped, the resulting pressure (water hammer) wave travels at the speed of sound c in the liquid, and the pressure increase from that stoppage is:
This pressure must be added to the prevailing static pressure to verify that the pipe is not subjected to excessive tensile stresses.
When a liquid of density ?, moving at a speed V in a rigid pipe, is suddenly stopped, the resulting pressure (water hammer) wave travels at the speed of sound c in the liquid, and the pressure increase from that stoppage is:
(?)(c)(V)/g
This pressure must be added to the prevailing static pressure .........
THIS IS A RESPONSE TO FLOW WITH BERNOULLI'S EQUATION which in original form does not include friction. AND is valid when the local velocity is negligible with respect to the sound speed.
My experience is that normally the local velocity IS small with regard to sound speed. However, if friction is not negligible, then another type of analysis (method of characteristics) must be used to determine the resulting pressure and velocity distribution in the pipe.
You did not specify if the fluid was compressible.
My response was for a highly incompressible fluid-such as a liquid.
However, if the fluid is compressible, then the approach to solve the pressure-velcity distribution should be done with the method of characteristics (MOC) approach.
And that would be an interesting topic for this forum to explore.
The fluid is incompressible. And frinctional losses are negligible. And I still have some questions. If a flow of low velocity nothing compared to that of sound etc, is stopped in its path. Based on Bernoulli's law,
The stagnation pressure = Static pressure + (rho*V*V)/(2)
So shouldn't the force = area * Stagnation Pressure
Based on
"This pressure must be added to the prevailing static pressure to verify that the pipe is not subjected to excessive tensile stresses" by 25362
25362 : According to you F = (?)(q)(v)/g
Dimensionally speaking
(F)is force (Kg m/s2)
(?)is density(Kg/m3)
(q)is ? (m4/s3) What is this term
(v)is velocity (m/s)
(g)is 9.8 (m/s2)
Also, is the static pressure term (P/?) in the equation, depending on the source or is constant in an environment etc.
Sorry guys if i sound too confused but i am.
I am trying to simulate this flow using FEMLAB.
Thank you for your time
IT IS NOT APPLICABLE TO :
Stopping the flow as related to sudden or changing the flow velocity.
Now at a point in steady state flow where the velcity is zero, one may apply stagnation properties to determine pressure.
q is flow rate, for example, m3/s.
Force can be expressed in various manners. For example kgf = 9.8 N = 9.8 kg.m/s2.
Thus, (kg/m3)(m3/s)(m/s) = kg.m/s2.
Dividing by 9.8 one gets kgf. I should have said that g is a constant = 9.8, and call it gc to distinguish it from the acceleration of gravity 9.8 m/s2.
Otherwise one gets kg which is a measure of mass, not a force.
Another way to express the perpendicular impact force would be ρAv2. By dimensions:
(kg/m3)(m2)(m/s)2 = kg.m/s2, which has the dimensions of force, as given by mass times acceleration.
Another way to express the perpendicular impact force would be ?Av2.
Please note-- for THIS steady state problem the force is related to the change in MOMENTUM. AND therfore for flow perpendicular to a surface one may use the incoming velocity AS the incoming momentum---AND the exit momentum is ZERO. The force from the net change in momentum in the icoming direction is as '25362 (Chemical)states'
I reiterate, if the FLOW, (not an individual path line) is suddenly changed, then the "water hammer" type equation must be used to detrmine pressure, velocity, force distribution.
