Number of Decimal Places <hw-depth> Hole or Thread Depth
I'm editing the calloutformat.txt file to match our
company's standards. I would like to change
<hw-depth> and <hw-threaddepth> so they display only
one decimal place rather than 3. Is there a file or
setting to change this?
Thanks.
Thanks.
RE: Number of Decimal Places <hw-depth> Hole or Thread Depth
1/4-20UNC-2B'.2
I see you can change the precision of <hw-threaddepth>
by right clicking the hole callout, properties, precision,
and changing the primary dimension setting to ".1".
Where can I permanently set this precision without changing
the precision of all other dimensions. I just want to
change the precision of <hw-threaddepth> and <hw-depth>.
Tools-Options-Doc Properties-Dimensions-Precision affects
the primary dimension which I still want to be 3 places.
I guess I could dimension an entire drawing and then when
I'm through I could CTRL-Click all hole callouts and change
the precision all at once.
Any thoughts?
Dimensions and callouts are grouped together in one filter, so you can not filter just callouts and window-select.
Seems like your ctrl-select idea is the only viable option.
Maybe a macro could do this?
