Capturing spec tree
Capturing spec tree
Capturing spec tree
When using 'tools-image-capture-pixel mode' Catia isn't capturing the spec tree only the 3D. Yet on my collegues machine it does.The option 'Capture only geometry' is NOT selected.
Ideas anyone??
RE: Capturing spec tree
Hi andyrich77,
Well, this is "work as design" ... according to APAR HD23304.
If resolution is set to LOW, the spec tree can be seen. Otherwise (Medium or Highest), it cannot ...
The above info will be updated on R14 online documentation.
Cheers. KT.
