How to edit scriptable Frame Object component
I am using MathCAD 2000 Pro, and want to insert a scriptable Frame object to collect the user's input. I've studied the example supplied in script.mcd and it works as expected. However, when I right click and select Edit Frame object, nothing happens.
If I insert a scriptable frame object into the worksheet, I get just the frame without any other components. I suspect that the Edit Frame object is where I need to go to add/edit the nested components.
How do I edit the frame to add dropdown and text box controls?
RE: How to edit scriptable Frame Object component
http://collab.mathsoft.com/~Mathcad2000
There are several Mathcad users who are very familiar with scripting and components.
TTFN
