Excel inserted into a drawing
Hi All,
We're having a problem when inserting an Excel spreadsheet into a drawing. I think we have it narrowed down to maybe an HPGL problem. When we insert a spreadsheet using the insert command, the first problem we encounter is that, if the spreadsheet is very long, catia will only show the first part of it, it cuts off the bottom portion. We've tried page setup, print area, everything we can think of, to no avail. The other thing that has to do with HPGL is that the part of the spreadsheet that does show up on the drawing ends up ploting way off the end of the drawing. The drawing preview show correctlly, and when the drawing is sent to a printer with postscript, it prints in the right position. This has got everyone here baffled, any help would be greatly appreciated.
TIA,
Dale.
TIA,
Dale.
