Steam Loss in Distribution Network.
Hi all,
I am analyzing the steam loss in our steam distribution piping network.  I have looked into the metering loss, insulation loss and steam quality loss, but they contribute a very small amount in comparison to the total line loss.  Does anyone have any suggestions or ideas?
Thanks in advance.
RE: Steam Loss in Distribution Network.
Murphymok
Are you talking about pressure drops?  Steam loss due to condensation in the piping?  As in we produce 1000 kg/hr of steam and when you sum up the end users of steam we only get 500 kg/hr of useable steam.
If you could define the problem a little better we could help you more.
Only an idea: steam traps passing steam ?
Is your indication of flow element flow corrected for pressure + temperature correctly?
Hi all,
We monitor the temperature and pressure closely and apply 0correction factors.  However, when I look at the steam sent out from the plants and the total sum measured at the customers, there is a huge steam loss, 10-15%.  We regularly check the distribution networks and manholes to ensure proper insulation and no leaks.  There are 3 losses I am thinking: condensate in piping, piping redundency and steam quality.
Any suggestions will be greatly appreciated.
Is there any reason to suspect the customer's ethics? A slight modification to their flow element can result in a lower indicated flow than they are using. All it takes is an electric drill during a scheduled pipe shutdown.
There is no change is steam quality, it is all saturated isn't it?
The condensation is the big factor.  But "25362" had a good comment, bad traps.  A hand full of small vents 24/7 can sure add up to a lot of lost steam.
If you are looking for 10% you are getting down to the fine points.  I was expecting you to say that you were loosing 40%.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
I assume you will have a boiler feed tank or HOTWELL. This will have a vent to atmosphere which loses steam.
Flash steam from processes will also affect the condensate line pressure and the pressure/flash steam in the hotwell.
If you use flash steam recovery, this will reduce
go to SPIRAXSARCO.COM
Friar Tuck of Sherwood
