sand blasting
sand blasting
can some one tell me why metal turns white when it is sand blasted? - I was just curious since I was quite amazed to see it.
RE: sand blasting
RE: sand blasting
RE: sand blasting
Metal shot for blasting will tend to produce a light gray or silver looking color because of the reflection of light off the roughened metal surface. If glass bead, walnut shells, or dry ice is used as a medium for blasting, you will tend to develop more of a matte surface finish that is not really white metal.
RE: sand blasting
The sharper the grit, the whiter the surface. It is not a function of grit residue. You get the same effect blasting with SiC or slag which are black.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
RE: sand blasting
Cheers,
Jeff
