SLM Propane relation to BTUs/Hr
What is the relation of SLM (Standard Liters per Minute) of (US) LPG usage with BTUs/Hr?
Conversions with BTU value per Gallon of Propane give me odd numbers! There is probably something I am missing between Liquid and Gaseous?
(1st time using Eng-tips, so I hope I am in right Forum?)
Thanks.
Thanks.
RE: SLM Propane relation to BTUs/Hr
You will need to do the math to convert these numbers to metric.
Franz
Just to be nit picking, I take it those figures presume US gallon, not imperial gallon, and the vapour is at STP.
pat pprimmer@acay.com.au
As you are aware, propane vapor is quite reactive to temperature changes, a 10° F (at 60°F) increase in temperature can result in a 1% increase in volume (not mass). The rate of expansion increases with the temperature.
Franz
