Force of impact of a pendulum.
I was asked to come up with a crude impact tester to test the failures of painted surfaces based on different impacts.  Heres what I've got: basic pendulum with hammer type head; weighing 2.2lbs (with pendulum; 5.5ft) attached by hinges to a crossbar, with an angleometer at the pivot point.  What I need to know is: using the angle from normal as a variable, how can I figure the force of impact given these criteria?
Thank you, Matt Booth, fts Technologies
RE: Force of impact of a pendulum.
Hi Destructotron
You need to know where your centre of gravity of your pendulum acts in terms of distance along the swinging arm from the pivot point.Then if you know its position or radius along the arm you can work out its vertical drop from say the horizontal. Having also established the combined mass of the arm and weight you can work out the potential energy of the pendulum as it reaches the vertical position just before impact with the sample. After impact the angle which the pendulum arm went through will be recorded on your device which you can use to see how much energy was left in the pendulum, just calculate the height the centre of gravity of your arm went through after impact and then calculate the potential energy = mass * gravity const* height reached.
Subtracting the potential energies before and after impact will give you the energy absorbed by the test piece.
I am not sure that it will be easy to calculate the actual breaking force that the pendulum delivers, however you will have the energy required to break the sample which you can use for comparison purposes.
regards desertfox
This is an inelastic collision. A conservation of energy approach will not give you the correct answer because you don't know how much of the total energy is dissipated as acoustic energy, heat, etc. You will need to use the laws of conservation of momentum to solve this problem. The momentum of the pendulum just before it impacts the test specimen will be equal to the momentum of the pendulum after the impact plus the momentum transferred to the test specimen. After determining the momentum transferred to the test specimen, you can calculate the force exerted on it provided you know the length of time that the specimen remains in contact with the pendulum at the point of collision.
                                              Maui
Hi Maui
I would just like to point out that the Charpy impact tests
are based on conservation of energy using a pendulum.
Secondly whilst I agree that I have made no allowance for friction, heat dissipation etc perhaps you could explain how using the conservation of momentum avoids losses due to friction and heat dissipation and how the length of time the
moving pendulum is in contact with the speciman can be determined easily without resorting to some high tech measuring equipment?
regards desertfox
First of all, thank you both for your input.  There is no data recording equipment involved with this project, the only source of quantifiable data is the weight of the pedulum arm/hammer and the angle at which it is released.  We are not too concerned with any specific loss of energy due to friction, heat or any othewr bi-products.  This is only a crude impact tester for our visualization and quantification puroses, used mainly for a reference point so we can see how much damage the pat will incur based on approximate impacts.
Hi Destructotron
Thanks for your response.
I suggest you use the energy balance that I outlined earlier, should you need any further help just shout.
regards desertfox
Destructo,
The tester you describe is nearly the same used to measure bullet energy in a ballistics tests some years past.  In use, a tape was attached to the pendulum and when the pendulum was struck, it pulled the tape through a retainer.
The length of travel was measured and energy computed.  This may give you some direction to search.  It also says your method has some validity.
Good luck.
Griffy
Destructotron, we need you to provide us with more detailed information regarding the experimental setup that you are using, including the specimen material and geometry, mass, hardness, how the specimen is fixtured, and what exactly occurs after the pendulum impacts the specimen. For example, is your setup fixtured like a Charpy impact tester where the pendulum actually breaks the specimen into several pieces upon impact? Or is the specimen held such that the pendulum does not break it into several pieces upon impact, but simply damages the painted surface of the specimen and then reverses direction after impact?
Desertfox, my reply was not intended to offend you. I am familiar with the Charpy impact tester and the theory behind its use. I also know that for tool steels such as airmelt H13, the scatter in the Charpy data is typically 50% or more of the actual test values at room temperature. For relatively low values on the Charpy scale, the test can result in significant scatter. Based upon your reply, you assumed that Destructotron was actually breaking his specimens during this test. But he did not state that he was doing this. He stated that he was studying the failures of painted surfaces based upon different impacts.
The force of the impact generated by the pendulum is equal to the time rate of change of the momentum, and one approach that could be used to accurately determine the net force imparted to the specimen is to determine the contact time at the point of collision. This can be accomplished by wiring a simple electrical circuit which is closed when contact is established between the specimen and the pendulum. In this circuit an inexpensive digital timer (similar to a digital stopwatch) can be included that turns on when the circuit is closed and turns off when it is open. This will provide an accurate value for the time of impact (obviously, an unpainted specimen will need to be run to perform this part of the test).
HI maui
No offence taken and yes I did assume he was breaking the samples.
I would also point out that if the samples are held rigid and are not taken to failure then the laws of momentum conservation are invalid, ie the sample does not under go a change in momentum and Newtons laws of Restitution have to
be applied in that case. However if the pendulum bounces back from the sample recording the height the pendulum centre of gravity reaches the difference in intial and final
potential energies will estimate the energy absorbed by the sample.
regards desertfox
Hi all
If calculating the impact force is as difficult as it seems, why not use the potential energy of the hammer as the basis for comparison of damage to the paint?
Easy to measure, easy to repeat.
Or drop ball bearings from a known height onto the painted surface.
Jeff
I didn't expect this kind of support... WOW!  We have tried the ball bearing drop test but the contact surface area is too small to compare to the damage surface area, hence the flat hammer head; in which we are using the surface area of to find a percentage of paint lost at each of the specific energy levels.  We are not breaking each sample we test; the majority of the parts are steel or flexible TPO's etc.  Each of these samples is fixed to a steel dummy automobile bumper and then anchored to a concrete wall, we are hoping that this will reduce the elasticity of the collision.  This morning we added a ratchet brake to prevent the surface from being struck more than once in each given test.  It seems as though the PE calculation is going to give us the approximate quantifiable force levels that we are looking for.  Just one quick question... What are the units of PE?  Once again thank you all for you help, you've made my life a lot easier.
Hi Destructotron
The units of energy are Joules
regards
desertfox
It's probably easier to state the energy in other units since these are available from direct measurement.  I would suggest ft-lb or Newton-Meter.  The Potential energy is then the weight of the pendulum times the initial vertical displacement.  Relating the pendulum vertical lift (D) to the angle (theta) and pendulum radius (R) is
D =  R-Rcos(theta)
Worrying about inelastic properties is most likely overcomplicating the problem.  I think one ought to view the problem from the perspective of energy delivered to the impact.
Also, there may be standardized industry-accepted procedures already.  Contact your paint vendor to find out.
Due to illness, the part of The Tick will be played by... The Tick.
http://www.EsoxRepublic.com
Desertfox, can you tell us in detail how to calculate the magnitude of the force exerted by the pendulum on the test specimen based upon your approach?
                                            Maui
Hi maui
Its not possible to calculate the force using the energy approach.
regards desertfox
The original post requested a  method for calculating the force of impact. I would also point out that the laws of momentum conservation are not invalid. If that were true, then Newton's laws of motion would also be invalid.
                                     Maui
Hi Maui
I pointed out in my first response that I thought the force
ivolved with the impact would be difficult to calculate this would be due to the small amount of time involved during the impact. I also pointed out that calculating the difference in energies was a means of comparison which also
seems to be the same thoughts as some of the other thread writers. I quote here from a text book "Mechanics For Advanced Level" by L.Bostock & S.Chandler , pub:- Nelson Thornes.
"The conservation of linear momentum is not valid in such cases for the impulse applied to the particle by the fixed surface is an external impulse; hence the momentum of the particle is changed but the momentum of the fixed object is not changed by an equal and opposite amount.
I consider the samples to be fixed objects and as such would fall into Newton's law of Restitution ie :- coefficients of restitution between 0 and 1. for calculating the speed at which the pendulum weight bounces off the sample. I think I mentioned Newton's law of Restitution in my previous post.
Maui your original post states that the energy approach is incorrect due to losses via heat, acoustic energy, friction etc perphaps you would be kind enough to explain how these
losses are avoided using your theory which I requested in an earlier post.
Regards Desertfox
Desertfox, you stated,"Maui your original post states that the energy approach is incorrect due to losses via heat, acoustic energy, friction etc perphaps you would be kind enough to explain how these
losses are avoided using your theory which I requested in an earlier post."
The statement which I made in my earlier post was,"This is an inelastic collision. A conservation of energy approach will not give you the correct answer because you don't know how much of the total energy is dissipated as acoustic energy, heat, etc." In other words, by using an energy balance approach you have no way to determine the errors introduced into your calculations due to the losses that I mentioned. If these losses are small enough to be ignored, then your approach will allow the calculation of the energy absorbed by the specimen due to the impact. If they are not, then your calculations will result in errors which may lead to incorrect conclusions based upon the results of these experiments. Such energy loss mechanisms do not need to be considered in the approach which I proposed because the error in my calculations is quantifiable based solely upon the accuracy of the measurements themselves. Yours are not.
The quote above taken from,"Mechanics For Advanced Level", describes the result for the limiting case of a collision between a particle of finite mass and one which is approximated as an infinite mass. If you choose to approximate the fixtured sample as an infinite mass, then it will make the calculation of the force imparted to the sample by the pendulum even easier.
                                              Maui
Maui
I stated:- I would also point out that if the samples are held rigid and are not taken to failure then the laws of momentum conservation are invalid, ie the sample does not under go a change in momentum and Newtons laws of Restitution have to
Your statement in the later post:- I would also point out that the laws of momentum conservation are not invalid. If that were true, then Newton's laws of motion would also be invalid.
If we are comparing what was said word for word then I said that the laws of conservation of momentum were invalid for the situation where the samples are fixed.
Further yes if we assumed the samples were fixed we could calculate the maximum force delivered to the sample assuming
that the impact was inelastic.
However your assumption of an inelastic collision is incorrect because to have an inelastic impact the pendulum and sample would have to coalesce ie there would be no seperation speed between them.
So if we have an inelastic impact in which the sample does not fail how do you measure the time of the impulse force as
your circuit would close but not open?
If the pendulum bounces off the sample then you cannot by definition have an inelastic collision. Reading the subsquent posts by Destructotron it appears to be an elastic collision which is why I stuck by the energy analysis once I realised that the samples were not being impacted to failure.
So for the record then you beleive that the conservation of linear momentum is valid in this case and that we have an inelastic collision then, explain what the velocity is of the coalesced sample and pendulum just after impact?
If you accept there is seperation between pendulum and sample after impact then what is the momentum of the sample
after this occurence as according to your theory it must under go an equal and opposite reaction therefore its velocity cannot be zero.
regards Desertfox
