Best heat insulator @ 700 degrees F
I have a heat stake application where I need to insulate my cartridge heater which I will be heating to 700 degrees F.
The heater will be in a piece of 1018 steel. I would like to insulate the rest of my mounting pieces from the heat.
I have looked at several ceramic materials and also at a high pressure laminate called Phenolic G7. We have used these materials with disappointing results. The ceramic cracked & the Phenolic G7 didn't insulate very well.
My question is, Is there a better material that I can use? I've seen simiar mechanical equipment with a "stone" type of material (it's not ceramic). Unfortunately our vendor will not part with the information of type of material or where they got it from.
Any help would be appreciated.
RE: Best heat insulator @ 700 degrees F
http://www.schundler.com/pbc.htm
good luck.
I suggest you look into FOAMGLAS. 900 F max temp.
Rigid with high psf capacity.
www.foamglasinsulation.com
Good Luck
pennpoint
I haven't used this myself, but the best insulation specs I've seen are from Microtherm http://www.microtherm.uk.com/index.html.
ko (www.ecooling.biz)
Ed
www.superiortechceramics.com
Click Materials
Supplier? I don't recall, I let pruchasing worry about that but I can find out if needed.
JMW
www.viscoanalyser.com
Eng-Tips: Pro bono publico, by engineers, for engineers.
JMW
