Hardware for Heavy Oil delivery, 1.00 gram
I need to deliver 1.00 gram of crude oil, meaning that I would normally have to heat up a syringe, or whatever hardware I should use, to 60-80 degrees C. The problem to solve, is to know afterwards the amount of oil injected/delivered, without having to measure the weight of the syringe/hardware before/after to see how much was delivered.
Anybody got some good suggestions I should check out ?
Martin
Martin
