Practical Implications of Zeros of a transfer function
- Zeros on the left hand side of the jw axis indicates that the system is minimum phase.
- Zeros on the right hand side of the jw axis indicates that the system is non-minimum phase.
- Zeros on the jw axis indicates that the system is 'marginally' minimum phase. The magnitude and frequency response of such a system indicates a phase shift of 2*pi rad between the input and output while the magnitude of the input/output response is 0db for a major part of the frequency range.
My Questions are as follows:
1. What is a transfer function without zeros at all referred to?
2. If the relative degree of a linear system is the difference between its poles and zeros, a transfer function without zeros has its relative degree = number of poles.
What does this mean in terms of the practical response of the system?
3. Is it preferable to have a system with left hand zeros or no zeros in terms of its transient response?    Looking at the bode plots, no zeros seem to support a wide frequency response.  However, at a certain frequency, the input is dramatically attenuated and the phase shift is undefined!
4. The zeros of a transfer function dictates wether its zero dynamics is stable.  Zeros of a transfer function coincide with the roots of its zero dynamics.  Does this mean that a system without zeros has no zero dynamics and therefore is advantageous when designing a controller?
Klaus
RE: Practical Implications of Zeros of a transfer function
First, if you find Root Locus plots abstract and baffeling, join the club.  As a practical design tool state space computer simulation has superceeded Root Locus plots.  Having said that;
1)I do not know of any special name for a no zeros transfer function.
2)All pole transfer functions are quite common.  The more poles in the transfer function, the greater the phase shift with frequency.  A zero (phase lead) may be added in the controller to either improve the phase margin (better damping of the step response) or a phase lead may absolutely be required to have a stable system at all.
3) The controlled plant may have a zero and that is not necessarly good or bad.  As stated before, a zero in the controller may be required to either damp the response or to stabalize the system.
4) Don't know.
Thank You.
