Balloons linked with view
I have an assembly and a drawing file with ISO view of the assembly in a sheet, now I also have 2 isometric views of indvidual parts from the same assembly. I have auto ballooned the assembly iso view and also auto ballooned the part views. Is there a way that I can have the balloon on the part view give the same number as it does in the assembly view for that part??
RE: Balloons linked with view
1. Select the balloon, in the property manager, change it to custom and type in the item number. It's not linked so if you decide to change it later, you'll have to manually update the text.
2. Another way is to create an assembly view, right click the view and select properties. Then hide all the components except for the one you want to show. A lot of work however if the assembly contains alot of files. Also alot of work if you needs several views.
Jason Capriotti
ThyssenKrupp Elevator
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
Vik
