Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...These forums are an excellent source and example of the way people can help each other..."
Geography
imtiyaz (Mechanical)
14 Aug 01 2:43
hi,
We have recently started planning using MS Project-2000. Is there any option to get S curve?
Thanks in anticipation,
imtiyaz
blooda (Mechanical)
14 Mar 02 15:47
Not as far as know
I have same Problem and export data to excel
sorry
AB
Rentaplan (Computer)
3 Apr 02 7:46
Hi Imtiyaz,
Like blooda, I have exported data from the task/resource usage tables to excel, the reason being that you can't hold progressive actuals to measure against the plan curve - all you can pull off are the latest values.
If you want to see a planned curve only, split the window to Gannt & Resource Graph (bottom pane). Then format the graph details to cumulative work (this will give you stepped appearance. Format the bar styles to line. This will give you an s curve for planned work only - unfortunately this is as far as you can go.
Good luck,
Rentaplan
santo2002 (Mechanical)
29 Aug 02 16:41
What I have done to obtain an ADVANCE s curve is to export the activity, start date and finish date, to excel, and make a formula that calculates the distribution of that activity in time with "IF". In columns, the time frame. then I compare the time frame with start and finish date, and it gives me the % of advance of each activity across the time. Then I find the incidence of each activity based on ManPower for example, and make a SUMPRODUCT of the incidences with its advance distribution, and finally obtain a beautiful and realistic s curve of ADVANCE. I can show you the excel file if you want.
Dont have information about resources S curve like Primavera does.
victormarcel@yahoo.com
sad1980 (Industrial)
9 Apr 04 14:35
hi
please show me that xl file
thanks.
9 Apr 04 15:22
hi
show me that file please.
thanks.
9 Apr 04 16:09
Hi Santo2002,
Thanks for the reply, I am develop something similar by exporting data in excel and using if statements. But it take lot of manhours and also if I revise the baseline, so again I have to do the complete file.
I would love to see your excel spread sheet.
Imtiyaz
Take care :)
12 Apr 04 9:57
You are right imtiyaz, every time you modify the baseline, you must go to the excel file and copy/paste the dates. This must be done every time you revise it / reschedule it.
It wont require a lot of man hours though ;), just copy and paste...
Sad1980, imtiyaz, please send a little message to my email, and I will reply it with the file.
Regards, Santo.
13 Apr 04 7:16
Hi
Thanks for the reply, I send a message to this address:
Thank you,
Verner (Mining)
6 May 04 14:33
Primavera will do S-Curves for you.
indxpt (Civil/Environmental)
25 Oct 05 10:09
well u can have the s curve in msp itself .go to view-resource graph. right click -choose cumulative cost.then choose bar styles and then choose filtered resources total costs and choose line. click ok there u have ur s curve with cumulative costs shown on vertical and monthly cost on horizontal line. ofcourse primavera has ready s curves
Frenchlady (Computer)
7 Nov 05 8:14
The Cube OLAP draws S Curve automatically based on the Work and actual work & Estimate to Complete info
Close Box
Join Eng-Tips® Today!
Join Us             Close
