Ball manufacturer
Ball manufacturer
Ball manufacturer
Hi I got a little question for you, do you know any company that manufacture metal balls for the ball valves?
Jonathan
RE: Ball manufacturer
joggmc1,
       just a question: do you need balls for small (let's say up to 2" 1/2) or larger valves?
       In the first case, here in Italy there are many Suppliers in the Brescia district, for example...
Bye,     'NGL
In fact it's for valves from 1" to 14", and if it's possible I'm interested in company in Canada first, or United states. Thanks.
joggmc1,
 Try www.abbottball.com
for a U.S. source.  There are fewer suppliers out there after so muuch of the industry moving off-shore.  You might have to consider Asian sources if your quantities would justify the hassles of importing the parts.  Check Google for "valve ball", and you will even get your eng tip post!
Here is one I came across on Google during my own recent search.
http://www.dkmachine.com/
ChemE, M.E. EIT
"The only constant in life is change." -Bruce Lee
