Multiple Column Width in Single Column
Hey all,
I'm trying to set up a schedule template for use in CAD. I'm using Excel 2000 and want to make a few columns one width for say 4 rows, but then shrink the width for the remainder of the column. Thanks for any and all help. If this is too vague (or impossible) let me know.
RE: Multiple Column Width in Single Column
Here's a sketch of what I'm trying to accomplish. The problem is if XXX's and YYYY's are in column A, and Z and A are in Column B and C, 2/3 of the XXX's won't be visible. Am I making this more difficult on myself than it is?
XXXXXXXXXXXXXXXXXX
YYYYY ZZZZZ AAAAA
i don't think that what you asked is feasible in a straightforward way.
I would leave the 3 columns and would use for the many Xs a format such as "center across selection" to 'simulate' to be in a single cell, while formatting Ys Zs and As in their own cells.
Additionally, removing gridlines and adding properly the borders around the cells you could give a customized format to the schedule.
Hope it will help.
_LF
thanks, didnt know about the center across selection format, will give that a try along with some border trickery as you suggested. i figured it wasnt too easy in a straightforward way, but thought maybe someone had a macro or something to that effect. thanks for the suggestions.
Select cells A1, B1 and C1. Right click->Format Cells->Alignment->Merge Cells
You will still have 3 columns under the "A1" super cell....
merging cells in a worksheet (not workbook).
otherwise, merging cells is likely the best option/solution.
good luck!
-pmover
