determining "activated" state with vb code ?
i'm using v5r12 sp6
if i have my catproduct file loaded and then view the spec tree, by noting the icons for each catproduct file, i can tell with is "Activated" or not, and so changed their respective activation states with a right-click/partname/Activate-Deactivate  mouse action.....
question: how do i do the same thing by using vb code?....what  api's are responsible for this kind of thing?
RE: determining "activated" state with vb code ?
One of the Properties of every Object in V5 is "Activity".  Set to True, it's activated.  Set to False, it's de-activated.
