Run CATIA V5 DownwardCompatibility Utility in Batch
Has anyone had success running the CATIA V5 downwardcompatibility utility on a CATDrawing in batch.  I am trying to determine the pointed documents and tried to get this information using the downwardcompatibility utility in batch.  However, it fails because it expects a CATPart and not a CATDrawing as input.  Interactively, you can run the utility against a CATDrawing in INFO mode.
