Removing overlapping lines...
New with autocad, curious if there is a way to remove overlapping lines in autocad, without doing it individually. I used some software to vectorize a raster image, and it outputs in .dxf format. Unfortunately it makes many overlapping lines. When I plot the file, it draws over some lines up to 4 times...which makes the plot take forever. Thanks for any suggestions!
-Andrew
-Andrew
RE: Removing overlapping lines...
