Importing data from Pro/E
I am new to Catia. I exported a Pro/E assembly file to ".model" using File Structure as "Ditto" i.e. the Sub-assembly and part structure of the assebly is maintained when opened in Catia.
Has anyone done similar thing before? What is the quality of this data in Catia?
Amish
Amish
RE: Importing data from Pro/E
TiĆ
In my case, I converted the ProE models into IGES or STEP (better) format then I can load either one of them into CATIA. Some color and material properties may be lost, but the structure, dimensions remain unchanged.
Once it has been loaded into CATIA, you can edit/modify to what you want.
I'm not sure if this is what you're looking for. Please let me know if you need more info.
I need to have the assembly structure in Catia. By your method, you must not be getting the individual part info.
-Hora
PhV
Pro/INTF-for-CAT module is not very reliable.
Peter
