Quantity of Same Parts
I am trying to create a custom BOM macro that displays the number of each part.  For example, I have an assembly with 10 parts total, but there are 3 parts named XXX and 7 parts named YYY.  How do I get SW to output these numbers (if possible).  Thanks.
RE: Quantity of Same Parts
Dear Creigbm,
Do you put a specificed properties each part configuration?
If do you put, no problems because do you want assign this specificed value to a BOM.
FerSW
FerSW,
A lot of models we create only have one configuration.  It would at to the difficulty here if I has more than one config.  I am working my way through the macro aamoroso recommended so hopefully that will work.  I was hoping for a simple modeldoc2.GetPartQty :)
