Florida Code Question
I grew up in FL but, although licensed there, have never practised in that state. I'm assisting a friend with the design of a custom home (CMU with fabricated wood trusses located near the coast) and am trying to decided which of the prescriptive manuals to purchase, if any. The FL Code allows the use of the AF&PA Wood Frame Construction Manual for One and Two-Family Dwellings - 1995 SBC High Wind Ed. 1996; the FC&PA Guide to Concrete Masonry Resident Construction in High Wind Areas, 1997; and the SBCCI SSTD 10. Additionally, a Florida Residential Building Code is to be published this month, if I've read the Code web site correctly. Other than the the Florida Building Code, what would any of you Floridians suggest? Thanks.
RE: Florida Code Question
What county are you designing for? If not Miami Dade area then should be no problem. Call the building dept and get there local guide.
See ICC Consensus Committee on Hurricane Resistant Construction (IS-HRC) ICC SSDT-1099 for typical details:
http://www.iccsafe.org/cs/standards/is-hrc/SSTD10/index.html
Foundations are a little different (Mono slabs). Roofs use prefab engineered trusses with lots steel hold downs and clips.
Good luck
Robert.S.Tucker@usace.army.mil
Thanks again.
http://www2.iccsafe.org/florida_building_code/btocia.htm
The drawing wind pressure reqs are given in para 1606.1.7
I'll Email the notes today.
