How to execute another program using CATscript
I need to build a CATScript to execute a process in the background using the following simple code:
Language = "VBSCRIPT"
Sub CATMain()
dim str1 as string
dim return_code as long
dim S as SystemService
Set S = CATIA.SystemService
str1 = "edit c:\temp\test1.txt"
msgbox str1 ' to display the string
S.ExecuteBackgroundProcessus(str1) <- Error: Method ExecuteBackgroundProcessus failed.
End Sub
I also tried:
return_code = CATIA.SystemService.ExecuteBackgroundProcessus(str1)
but it also failed.
Can anyone help me to find out what the problem is?
Is there a better way to invoke another program using VBScript from within CATIA?
Thanks a lot
Sub CATMain()
dim str1 as string
End Sub
I also tried:
but it also failed.
Thanks a lot
