Heated and Bent Anchor Rods
Concern:
On a current job site, several 1 inch anchor bolts/rods were poured into column pedestals out of plum. Construction workers decided to torch heat the anchors and bend the exposed 5 inches back to straight, with 17 inches imbedded in the concrete. The anchors have visible heat marks and some scortched threads. The concrete surface surrounding the anchors now has a glassy appearance. The anchors were bent to accept the base plates and are now being questioned by engineers as to how this heat treatment has affected steel properties. A tension load test has been requested, but not yet performed. Quality Inspection has proven to be poor on the site and the contractor wants a, "The anchor bolts are okay, no fix is needed," type of an answer. However, this answer cannot be provided without additional information. If anyone has good material science knowledge or has been faced with a similar problem, your comments on this subject would be greatly appreciated.
RE: Heated and Bent Anchor Rods
For 1" diameter material, pre-heat and post-heat could be required to properly accomodate the heating for straightening.
Rebar is a generally a mixture of many different kinds of scrap steel, thus the variable properties.
An in-place load test would be appropriate.
After you get results, please post and let us know how it turned out.
