Mg corrosion protection
I am looking for a corrosion protection "coating" that I can apply in my shop to protect magnesium aircraft castings from corrosion by water at about 100 F.
RE: Mg corrosion protection
The proper procedure includes cleaning, pre-treatment, and coating.  I doubt that you can do all of these things in your shop.  Be that as it may, a typical process would consist of alkaline cleaning followed by acid cleaning (nitric-sulfuric acid or chromic acid).  There are numerous pre-treatments that exist including chrome pickle, sealed chrome pickle, fluoride/chromate, anodizing, etc.  Coating would then typically be an epoxy primer followed by a polyurethane topcoat.  An excellent paper describing the development of a highly-corrosion resistant coating system for a magnesium helicopter transmission (anodizing + epoxy sealer + epoxy + polyurethane) is available on the Tagnite website (anodizing vendor).  Use the following links for more information, or obtain a copy of ASTM D 1732 Standard Practices for Preparation of Magnesium Alloy Surface for Painting or MIL-M-3171C.
http://my.noranda.com/Noranda/magnesium/Working+with+Magnesium/Finishing/_Finishing.htm
http://www.finishing.com/faqs/magnesium.html
http://www.tagnite.com/techreports.htm
http://assist.daps.dla.mil/eAccess/index.cfm?ident_number=3722
TVP, you deserve a *
