File Reversion Autocad 2004Dx
Has anyone eles had this issue? Recently a couple of our designers have made some changes to some ACAD files, saved them and then re-opened them later the same day or several days later only to find that the changes they made didn't save. It almost seems like Autocad is re-opening the bak file and not the dwg. Has anyone else experienced this? Is this a bug? Is there a fix?
RE: File Reversion Autocad 2004Dx
a) operator error - check that they are the same files in the same location and that they were saved.
b) you should re-install acad and clean your computer
c) check no-one has changed the save icon button properties to somthing like "undo back y qsave close " (unlikely, you would hope)
