Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I have never been to any technical site that shows concern just to anybody with problems...I look forward to also share in the future..."
Geography
curve3104 (Mechanical)
8 Jul 04 13:16
Does anyone know how to calculate the drum holding time for an industrial watertube boiler?
I have seen requirements for boilers to maintain "X" minutes of drum hold time before the low water alarm trips.
Any ideas how this is calculated?
Helpful Member!  davefitz (Mechanical)
8 Jul 04 14:23
The X holdup time is typically based on the  measured liquid volume between normal water level NWL and the lo-lo water level trip .
The lo-lo level is the min level needed to ensure the water flowing down the downcomers does not entrain excessive steam and thus avoid upsets to the natural circulation. This might be 12" above the drum invert, but varies according to downcomer size and water velocity into the downcomer bellmouth.
The NWL may be set Z" below the hi water  level, as needed for water level measurement accuracy and margin to control fedwater flow, perhaps a 30 sec - 1 min volume between hi level and NWL.
The volume of water contained in the drum at these different  heights can be calculated using simple formulas for the area of a circular segment.
GenB (Mechanical)
11 Jul 04 0:31
you may find your answers in the ASME CSD1 controls Code.
ER
Close Box
Join Eng-Tips® Today!
Join Us             Close
