casing pipe design and spec
I am working on a project which need do a steel casing pipe design (Carrier Pipe D=42", Soil Cover=17'). Where can I find some information to do calculate and spec for jack bore?
RE: casing pipe design and spec
good luck
Have a nice weekend
We typically use 3/4 or 5/8 inch thick pipe for the casing. Don't forget that this pipe not only needs to support the earth above, but be able to withstand the forces of the jacking.
In this project, there is a higher soil cover. I use 60" dia. casing pipe and get norminal wall thickness is 0.9", so use wall thickness 3/4 inch and predicting ring deflection is about 1.15%. What do you think according to your experience?
Unfortunately, I'm not really an expert on this. I've utilized boring and jacking so I know a little about it.
