resolving equation expressing dataset in matrix
Using the following setup i can interpolate values related to a two-column matrix:
X:=data(0) y:=data(1)
S:=cspline(X,Y)
fit(x):=interp(S,X,Y,x)
fit("value") = "returned value"
Is there any vay that i can get mathcad to return an equation expressing the dataset in my matrix ?
mathcad-beginner
S:=cspline(X,Y)
RE: resolving equation expressing dataset in matrix
Bung
Life is non-linear...
The eksamples work but they don't give me an equation that I can use in another software to calculate y-values from a given x-value...?
Is there a way to get Mathcad to return the exact equation instead of general formulas and functions ?
(I want to get an equation that I can use in an HMI-system to calculate condensationtemp for gas at a meassured preassure)
Moreover, if you have "data", the implication is that the data is non-exact, due to measurement noise, etc., which means that splines are not the correct approach, since the purpose of the spline is to ensure that the generated curve tries to go through each data point, thus incorporating your process noise into the interpolation.
It's your data and process, so ONLY YOU can know what equation best fits the data. There are a number of functions that will tell the best fit to a particular equation that you provide, e.g., linfit and regress. These are described in the Mathcad help section on Curve fitting.
TTFN
Of course, if your data does not conform to the type of curve you are trying to fit it to, you will get funny numbers - GIGO. Eg trying to fit data from an exponential function using logfit() is not productive. If you don't know what your data is, you can't expect any software to tell you. Mathcad will only do what you tell it to, and if you want it to fit an inappropriate function to your data it will do just that.
Bung
