[b]End of File Missing, Attempt Repair[/b]
I am looking for some help from the microstation gurus out there. I have been running Microstation SE along with Eaglepoint 99 on Windows 98. I have recently upgraded machines and am now running Windows XP. I have been getting error messages reading "End of File Missing, Attempt Repair?" when I go to open a drawing. Everything I read tells me to answer "no" to this question and then I am able to reopen the drawing. This is an inconvenience but I can work around this.
The problem comes in when I have to use Eaglepoint to open a drawing. Eaglepoint attempts to launch Microstation, but I get the same error message but am not able to reopen Microstation and the screen goes white. I am asked to run Eaglepoint without opening CADD which does me no good at all.
Does anyone else have this problem and if so is there a patch or something I can do. Right now all I can do is run Microstation but can't do any design work using Eaglepoint. Any help would be greatly appreciated.
RE: [b]End of File Missing, Attempt Repair[/b]
