EN Standards
EN Standards
Good Afternoon Materials Engineer:
Can you help me identify plate material meeting EN 10028-2 P265GH? Can you tell me what the ASTM equivalent is? Can you refer me to a producing mill? Thank you for your help.
Thanks for your help, Kent.
RE: EN Standards
RE: EN Standards
According to the British Pressure vessel code PD5500:- P265 has a design strength of 176N/mm2, A516 and A515 Grade 70, according to code case 91, are given a design strength of 175N/mm2.
But they are still not the same, as the EN steel will be subjected to more stringent mechanical testing than will the ASTM equivalent.
John www.gowelding.com
