Basic dimension
Basic dimension
Is there an importance on how many places after the decimal in a basic dimension has. I have not found anything that states how many places, but all the references I have seen show 3 places.
RE: Basic dimension
RE: Basic dimension
There is no significance to the number of decimals after a basic dimension as per ASME Y14.5M-1994. The feature you are dimensioning is controlled by the geometric tolerances you have applied.
The standard states that you do not show the trailing zeros on metric dimensions. I would assume that this is done to make metric drawings look different from English units. I wish my CAD software sould support this properly.
If the dimension is not basic, ASME Y14.5M-1994 allows a tolerance note to define tolerances as per the number of decimals.
RE: Basic dimension
RE: Basic dimension
