Qeustion concerning ASTM D2699/2700
RE: Qeustion concerning ASTM D2699/2700
There would prob not be new precision and bias data unless the test has been altered.  ASTM rarely allows existing tests to be modified.  They make you add new ones.
Since there are -04 revisions of both specs you should buy new copies.  That is your responsability.
Hint: You can join ASTM for $75 and get one free book with your membership.
If you buy these as singles they are about $55 each.
The book that they are in, 5.01, is $280.  Or free if you join ASTM.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
thanks for the info. i know it's not that expensive to get the newest edition, but it is timeconsuming and essentially useless because i just want to verify two numbers.
