controller for a Tank.Two engines(each both way ...)
Do you know a controller like the Vantec one, but for brusless engines. Both monitored with only one stick and beeing able to run either way separetely (by example if the tank turn on his axel one go forward and the other back wards....
ANd when you drive and you want to turn right, the right engine slow down while the other keep the same speed.
There is only one stick for driving and for speed.
If you know any controller which could do that, let me know. If you think it's possible to have the same result with two controllers, I would think it's fine also.
Thank you for your help
François
François
RE: controller for a Tank.Two engines(each both way ...)
http://www.thomasregister.com
and type Controls: Brushless DC Motor which will return six companies to choose from and contact in addtion to what you have available from Vantec
