Setting up CAD system standards - help!!
The engineering group that I am in has just purchased a new CAD system.  Over the past years each person in the group has developed their own little ways of drawing, so now all of our drawings look somewhat different.  I see the new system as a perfect opportunity to standardize our format (ie. line weights, fonts...) but don't really know where to begin.  Please point me in the right direction.
thanks...
RE: Setting up CAD system standards - help!!
Set up standard drawing format templates. Also everyone should be following standard drafting practices, ie MIL-STD-100, ASME & ANSI, etc.
What CAd system do you have? Each has their own metod for setting up company wide standards.
I have experience with UG and Pro/E where we have have 50+ workstations all using the same set of standard formats and default settings.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
If you are using Microstation and are doing work for a D.O.T. if you go to thier respective web sites you will find thier standards already for set-up and download.
Namdac
