Specifications weight of heightemperature steel
I was looking for some specifications of X 10 CrNiTi 18 10 or X 10 Ni Cr Al Ti 32 21 on the net but found nothing about it.
I need especially the weight of them for m².
Thanks a lot,
RE: Specifications weight of heightemperature steel
Mass is a volumetric property, so the mass must be specified per cubic meter, not per square meter, unless you fix one of the dimensions.  For your alloys, the mass density is near 7 900 kg m-3.
Cory
