dielectric antenna
dielectric antenna
Antenna size can be reduced by loading the antenna with dielectric material. Because the wavelenght is shorter in the dielectric the size of the antenna can be made smaller for a certain electrical size. What happens with directivity and gain? Is the radiation efficiency changed?
What about the effective aperture for communication link calculations? It should be reduced or does the antenna somehow gather power from bigger area than what would be expected of its physical size? Or is the only benefit to achieve resonance and match with smaller physical dimensions?
RE: dielectric antenna
bandwidth generally reduces proportional to the sqrt Er
waves generated in the dielectric tend to make it less efficient (though you may not notice it unless you're really trying to squeeze every dB of gain out of a tiny antenna).
effective aperture (directivity/gain) would reduce alot if you have a high gain antenna and embedded it in dielectric, and hence it's size shrinks alot, but if it's a small antenna like a monopole, you see a smaller reduced effective aperture change when you load it with dielectric.
A note on directivity versus gain. Directivity is just related to the pattern shape (i.e. narrow beam is high directivity, wide beam is low directivity). Gain is identical to the directivity if the antenna and it's combining network is totally lossless.
Directivity formula = 41,000/[(Beamwidth Az)*(Beamwidth El)]
A common number for Gain replaces the 41,000 by the number 30,000 to account for a small amount of loss and the loss due to the VSWR of the antenna. example: A standard waveguide antenna with 10 degree beamwidths has gain = 30,000/(10*10)= 300,
Usually 10*log(Gain) is specified by manufacturers, hence this gain would be 24.8 dBi(L).
kch
