Assembly parameter not available in part
Hello.
I want to use the same parameter to rule several parts of the same assembly.
I have created a lenght.1 parameter in my product assembly root, but this parameter is not available in the sketcher.
In the formula editor, if i link a sketch dimension by clicking to lenght.1 in the root it only reproduces the lenght.1 numerical value but isnt synchronized.
Anyone knows?
Anyone knows?
RE: Assembly parameter not available in part
While you're there, deselct the Only use published elements... option or publish the assembly parameter.
Best regards
You need to drive the parameter of sketch from assembly.
You have a parameter Lenght.1 in assembly level
Create a relation that drives sketch lenght to assembly level (not inside a part).
Example:
Part1/PartBody/Sketch.1/Lenght.1=Lenght.1
Product1
L Part1
| L PartBody
| L Sketch.1
L Parameters
| L Length.1
L Relations
L Part1/PartBody/Sketch.1/Lenght.1=Lenght.1
