Wastewater treatment
How applicable is the use of MBR(technology) for wastewater treatment in rural communities?
RE: Wastewater treatment
Usually land is relatively plentiful and cheap in a rural location. MBRs can however give very high solids removal efficiencies, which can be desirable if discharging to a high-grade water body, as is nmore commonly the case in rural locations.
MBRs are more expensive to purchase and to run than the simpler activated sludge treatment for anything other than the highest degrees of treatment.
Seán Moran
www.wastewatertreatmentplantdesign.co.uk
ENREM (Enhanced Nutrients Removal in Membrane bioreactors) is a European project to demonstrate the faisability of MBR waste water treatment for smaller communities of 250 to 1000 p.e. without industrial wastewater. A demonstration plant should be built in Germany.
Some links for a first orientation:
http://www.kompetenz-wasser.de/engl/projekte/Proje...
http://europa.eu.int/comm/environment/etap/pdfs/et...
hope it helps
Pierre.Strauch@orelis.de
www.orelis.de
