Looking at TriLogi PLC.. any other low cost alternatives?
Hi all,
I have an old project from my last year of college sitting in my basement that I'd like to bring "back to life".
Originally it was controlled using an OMRON CS1G controller, and that was definitely overkill for this control application (those were the PLCs available to us at the time). I had to give the PLC back to the school after I graduated. Actually, I was very happy with the OMRON PLC and its programming software (CX-Programmer). However, the cost of purchasing a new one (even a micro) is a bit of a deterrent, considering this is more of a pet-project.
I have been researching my alternatives, and (through Eng-Tips banners) I have found the TriLogi line of embedded PLCs.
I like the relative size of TriLogi PLCs, and they seem simple enough to program for my application. My application does not require any overly-complicated programming instructions, and I believe that the Ladder+Basic style of programming offered by TriLogi PLCs will work very well for my needs.
However, before I fork out a few hundred dollars on my new control system, I'd like to ask the group if they have had any experiences with these PLCs in the past, postitive or negative. Also, is there anything comparable on the market?
As of now, my criteria are (in order):
1)Form Factor (size)
2)Cost
3)Ease of programming
4)Remote operation (web-based monitoring/control is a plus)
It seems to me that the TriLogi PLCs fit in with all of these. Is there anything else on the market that I should be looking at?
I am a Mechanical Designer, so control system design generally isn't what I do (unless I'm designing an enclosure). Like I mentioned, I'd just like this "invention" of ours to stop collecting dust. I actually want to get my girlfriend's younger brother to help me get this going, as he is at that stage of his life where he has to choose a college program. He's a smart kid, so I want to introduce him to the world of engineering with some hands-on work. My uncle did it for me and here I am!
Thanks, any help is appreciated
-Mark
2)Cost
-Mark
RE: Looking at TriLogi PLC.. any other low cost alternatives?
PC compatibles
<nbucska@pcperipherals DOT com> subj: eng-tips
A programmable relay: The Zelio; chepeast and depending on number of I/O it is all you need.
A PLC: The Twido; a little more expensive but can get analogs as well if need be.
TULUM
The online catalog system is so huge that it is a pain in the butt to use, but the products are good. The paper catalogs are equally awful to use, but make excellent doorstops.
https://mall.ad.siemens.com/WW/guest/index.asp?aktprim=0&nodeID=5000562&lang=en&foldersopen=-1366-856-855-854-1-&jumpto=1366
If we learn from our mistakes,
I'm getting a great education!
I would really be interested in knowing what benefits you see Scotty?? I mean there really is nothing to either of the controllers???
TULUM
I agree that from a user interface point of view there is little to choose between the two ranges. The Siemens product is perhaps a little better established in the market than the Telemecanique range, but that could well change over time as the Siemens range has been around longer.
It is just a personal opinion, but I think that Schneider's automation divisions have, across their European range at least, replaced some old-established product ranges with alternatives that are less well constructed and have poorer reliability when compared to their predecessors and when compared to their main competitors.
I've had a few of the new Zelio range products simply die on me for no apparent reasons - timers and the like, not the more sophisticated modules like the Zelio 2 - as well as problems with other parts of the Schneider range: emergency stop buttons where the contact block falls off the actuator, leaving the drive running; ACBs where the protection modules failed; contactors burning up on loads within rating and within ambient temperature range; motor thermal overload relays which won't reset; etc.
I've just had a Modicon PLC arrive on site as part of a packaged system, and I had major reservations to the extent that I considered paying a premium to have an A-B or Siemens PLC instead beause of the bad history that Schneider has at our plant. Users on Eng-Tips say that the Telemecanique PLC it is actually a very good product, so I've accepted their advice and allowed it to be used. Time will tell!
Sorry to hear about your mis-fortune with Schneider products. I have designed and commishioned literally hundreds of schneider units which included many items from pushbuttons, disconnect switches, PLC's, all the may to their line of Merlin Gerin MV breakers and really had no problems...no problems at all...
The only thing I can tell you is delivery from Schneider is very lengthy and sometimes can get you in a jam.
TULUM
Interesting: I find their stuff dead easy to get hold of. Delivery is the curse of Siemens over here in the UK - other than really common items, almost everything is made 'just in time', or more accurately 'just a bit too late', in the German plant and we have to wait a few days for it to be shipped over. It makes increased stockholding on site a problem which we could do without.
Although we are phasing our Keyence units because of
communication capabilities, I find them to be a pretty reliable unit and the software is not very expensive.
Last year I had a salesmen demonstrate a new pico unit from Moeller that was small and easy to program. I believe you could program it from the display on the face of the unit and avoid buying any software at all. This Moeller unit may be a perfect fit for a pet project where the speed of programming the unit is not an issue becuase of lost production.
You will have to look at the communications for each of these units for your application.
Good luck,
Afterhrs
I still kind of like the TriLogi though because the programming software is free, and it comes packaged with a little LCD screen that would work quite well for this application.
Etom- thanks for the offer to donate a controller, & thanks to all for your replies.
-Mark
The DL05 is a small form factor (Nano class) PLC starting @ $99 for 8 Inputs & 6 Output. The programming software for this PLC is also $99.
The options go up from there ...
