Drilled Shaft Production
Anyone have an idea of what the production rate for drilling a 6' diameter drilled shaft through 8000 psi concrete would be?
RE: Drilled Shaft Production
If the concrete is not very old and still green it could move right along.
Qshake
Eng-Tips Forums:Real Solutions for Real Problems Really Quick.
Good Luck
If you use a pier rig, you are likely to damage portions of the slab in the vicinity of the six foot hole. In that case, jackhammering would be preferable to using the pier rig -
Please see FAQ731-376 for great suggestions on how to make the best use of Eng-Tips Fora. See FAQ158-922 for recommendations regarding the question, "How Do You Evaluate Fill Settlement Beneath Structures?"
