different color sketches in part-is it possible to do?
I want to put 3 sketches on a part, with different colors, to help me from messing up any more than usual.  Is there a way to do this?
RE: different color sketches in part-is it possible to do?
Nevermind, I wasnt seeing the forest thru the trees.
Related question
Is it possible to change colors and line styles for specific entities in a sketch? Whenever I try to do this SW always applies the changes to the entire sketch.
I'm used to being able to change the display for specific geometry on UG can this be done on Solid Works?
Michael
AETD - LYNN, MA
I changed the options so that constrained sketch entities are a different color (dark green).  Makes it easier to distinguish from other grey or black lines.  It also helps to have sketch endpoints and arc centers visible (set under "Tools --> Options --> System Options --> Sketch")
Due to illness, the part of The Tick will be played by... The Tick.
http://www.EsoxRepublic.com
