Steam verses hot water distribution
Is there a general guide or reference to help determine if a hot water system or steam system should be employed for a central plant?
RE: Steam verses hot water distribution
For same heat capacity, generation and distribution cost for hotwater system is more compared to steam system.
2) Some jurisdictions treat hot water systems more leniently than steam systems. For example, the aforementioned system does not require continuous monitoring by a stationary engineer, and the municipal approvals for 'hot water' were easier than they would have been for steam.
3) It is easier at the loads to use water/water heat exchangers rather than steam/water, if the loads include domestic hot water and hot water heating.
4) Sometimes, there is more potential useful waste heat available to a system that only requires 100-125°C of supply temperature than to a system that is looking for steam as source.
