Drawing views disappear when I make a change to config.pro
I'm using Wildfire to create a drawing. I had to change "tol_display" to yes and "tol_mode" to nominal.
When I go back into the drawing the views go away and only the centerlines are visible. I did a regenerate and update views and they are not reappearing.
Thanks in advance,
Matt
Thanks in advance,
Matt
RE: Drawing views disappear when I make a change to config.pro
Go into View-->Display Settings-->System Colours
Then select Scheme--> Default.
For some reason, Wildfire was changing my colour scheme on me sometimes. I'm not 100% sure what caused this (a config.pro mixup may very well be the reason).
I updated my datecode to M150 and this seems to have stopped happening.
Hope it works
-Mark
