10 node tetra
10 node tetra
10 node tetra
If I generate a model with 10 node tetra elements during the analysis my machine is frozen. Does aqnybody why?
Irwin
RE: 10 node tetra
Just a guess, but it sounds like you are running out of memory.
Joseph K. Mooney
Director, Airframe Structures - FAA DER
Delta Engineering Corporation
RE: 10 node tetra
If I create only 10-20 elements I will get the same result.
Irwin
