What are Vyro and Sahrs sensors?
What do vyro and sahrs sensors measure?
RE: What are Vyro and Sahrs sensors?
I'm not sure about SAHR - the only reference I know of is to the Self Aligning Head Restraint used in some autos; I don't know if this makes sense in your case.
Hope this is of some help,
RIKMAN
Sahrs = Standard Attitude Heading Reference System
Vyro
Dr. Stephen W. Tehon successfully applied piezo- electronic technology to vibrating angular rate sensors used on aircraft, line of sight camera stabilizers for camcorders, and rotating detectors for automotive anti-skid systems.
He is a pioneer in the development of vibrating angular rate
sensors, generally called piezo-gyros. In 1970, he received a patent for a vibrating bar, angular rate sensor, while he was at the GE Electronics Lab, in Syracuse. The immediate use was to the improved control of military aircraft. The vibrating bar piezo-gyro eliminated the bearings and suspension required for the conventional wheel gyro.
GE subsequently manufactured the Tehon piezo-gyro (renamed the VYRO) in central New York. They are now used in military aircraft such as the A-10 Wart-Hog and the V- 22 tilt-rotor aircraft.
Consumer applications include stabilizing video camcorders, rotation detectors for automobile anti-skid systems, and stabilizing antennas on moving vehicles.
