dB Connect Manager
dB Connect Manager
dB Connect Manager
I am working for a company that does system integration of audio/video systems.  When I create block diagrams showing signal flow, I would like to be able to insert my standard blocks and have pertinent information, such as connector types, electrical information, and wire types accumulated "someplace" in AutoCAD.  Later, I would like to query AutoCAD for a total list of those characteristics to be more accurate with job preparation prior to installation.
Can the dB Connect Manager/commands be used to create such a database in AutoCAD or am I misunderstanding the use of this command set?
I am using ACAD 2004, BTW.
Mark P
RE: dB Connect Manager
You will need to program your own routines to query/store your info to a db if that is what you want. You can also store the info with your blocks as attributes and then query the blocks with your own routines within AutoCAD.
"Everybody is ignorant, only on different subjects." — Will Rogers
